First Ideas
A project log for Happy Clap Switch
Clap-clap, light goes on. Clap-clap, light goes off. This makes me happy.
alan-greenAlan Green 05/11/2019 at 23:020 Comments
I wanted a clap switch to make my life easier. My bedroom light switch is at the doorway, but bedlamp switch is at the bed. A clap switch  saves me from choosing between fumbling for the bedlamp switch after turning off the room lights, or having to walk to the bed and turn on the lamp before going back to the door to turn off the room lights.
An inspiration here was DIYODE magazine's Three Stage Clap Switch project. I built that project on a breadboard, using a BoldPort Cuttle instead of an Arduino. It worked mostly OK. However, I had bigger plans.
First Plan
My first plan was pretty simple: take my existing bedlamp, use its power supply to power an ATTiny microcontroller. When the ATTiny detected a clap, it would switch a MOSFET to turn the lamp on and off.
I was keen to use parts I had in my cupboard, without buying more. I tend to buy components in fives or tens, and this has led to me having, well, a cupboard full. This leads to choices such as:
I also wanted to use my new prototyping board, BlueBoard#01. By no coincidence at all, I have a microcontroller and microphone that fit it perfectly.
