Construction
A project log for Happy Clap Switch
Clap-clap, light goes on. Clap-clap, light goes off. This makes me happy.
alan-greenAlan Green 05/21/2019 at 12:000 Comments
It's green!
It's purple!
I began by drawing the component layout onto planning sheets
Sadly, I lost these sheets. It was super-helpful to have them to work from, but I did change my mind, mid-construction on a few items.
Soldering Components
I have done quite a bit of prototyping with BlueBoard#01 and its predecessors. Soldering components is about as quick as soldering to a PCB. Wires are extra, but I minimized wire runs by using through hole component leads to jump between ICs, particularly around the microphone and op-amp,
This came out nicely
ATTiny3217
Not so pretty
Hand soldered SPU0410 MEMS microphone
Encoders
Encoder with drilled out hole for peg
The encoders each have three leads at 0.1" centers, as well as two additional metal pegs to help secure it to the board. I was able to drill out 2mm holes in the PCB, which fit the pegs perfectly.
WS2812s
The WS2812s are connected with 3 wires - 5V, Gnd and Data, which I braided together for strength and neatness. I used a 3 pin header and plug because I happened to have them - otherwise I would have soldered the wires directly to the prototype board.
A Case
Initially, I had the idea of laser cutting a case for the switch, but I found some PCB standoffs, and it occurred to me that I had something that already had holes drilled in exactly the right location - another BlueBoard#01, so I used that. I think it looks fine.
The encoders, buttons, connectors and a couple of wires are on the top side of the board, while the rest of the components are on the bottom side, out of view. This is acceptably neat.
