Design Goals
A project log for 350 Watt True Sine Inverter
Functional design revision of the prototype TS350.
Brian CornellBrian Cornell 05/08/2019 at 21:130 Comments
The prototype 350 I did last year was just that.  It was never viable for anything off the bench but it was a great learning platform.  The R1 is meant to be a refinement that actually works:
It mostly meets these.  Two problem areas are dissipation and poor regulation at high loads (low output voltage).  Neither are show stoppers and its another opportunity to learn & improve.
