LoL Akali's Mask
Akali's Mask - cosplay mask with synchronized transitions between mouths for a cosplay on Leag Of Legends' character Akali
A friend of mine had one goal in mind: get the same mouth animations as the ones in <a target="_blank" rel="noopener noreferrer" href="https://www.youtube.com/watch?v=nFta3Ao9E9I.Additionally">https://www.youtube.com/watch?v=nFta3Ao9E9I.Additionally</a>, she had to have it cycling through stored mouths at specific moments, for the transitions to be synchronized with an ongoing choregraphy &amp; music being played.The current state of the project offers exactly that:- stored mouths generated from a script ran within an Adobe Illustrator document- a single button press to cycle through set mouths at set moments or stop &amp; reset- 2 basic color modes: same color for all mouths ( can be adjusted in real time ), or using the colors of each teeth from the original illustrator layersThe projet now needs a proper casing &amp; 3d printed diffusers for the leds to be more perceived as teeth through cutoutsA second &quot;hand-made flexible pcb&quot; was done ( this time, with kapton under the t
Peeling off the bottom-up cutted copper tape ( 2nd version of the traces )
JPEG Image - 1.92 MB - 05/09/2019 at 11:29
Preview
Yup, we're all cleaned up here !
JPEG Image - 2.18 MB - 05/09/2019 at 11:29
Preview
Preparing the kapton protection on the plastic support to prevent burns like in the previous version ..
JPEG Image - 2.19 MB - 05/09/2019 at 11:29
Preview
Now onto peeling off only what's not traces :)
JPEG Image - 2.11 MB - 05/09/2019 at 11:29
Preview
Everything went quite well, but I scratched the kapton in some places ( staying focused on precise work for some hours is quite hard sometimes ) - also, there are missing trace(s) ( I think one or two little ones ) that I'd either re-cut & place manually or simply replace with a tiny wire ;p
JPEG Image - 2.05 MB - 05/09/2019 at 11:29
Preview
View all 41 files
