A laser-cut test fixture
A project log for BB Q10 Keyboard PMOD
A BB Q10 Keyboard in PMOD format!
arturo182arturo182 01/27/2020 at 23:200 Comments
Over the weekend I whipped together a quick acrylic fixture to make testing of the boards easier.
I made the design in Fusion 360, I got the model for the clamp directly from the manufacturer, Good Hand.
The design is fairly simple, it uses 2 pieces of acrylic to hold the PCB in place and align it with the clamp, then the clamp has a small 3d-printed part that allows me to attach pogo pins to it so I can toggle the clamp and lock the pogos onto the board.
