Testing the assembly
A project log for The DIYson, an open source Cyclone vacuum cleaner
Why buying an expensive cyclone vacuum cleaner when you can build yourself one?
madaeonMadaeon • 05/13/2019 at 10:51•0 Comments
It works! Now is time to 3d print the remaining parts. The whole system is designed to be modular, so I can focus on the multi stage design, air filtration where the air exits, best design for the air intake later.
