Designing the DIYson
A project log for The DIYson, an open source Cyclone vacuum cleaner
Why buying an expensive cyclone vacuum cleaner when you can build yourself one?
madaeonMadaeon 05/13/2019 at 10:190 Comments
This rendering shows the air path of the DIYson V1.
It is a mono stage design, but for the first iteration, it is enough, and it works already!
There is a carbon filter at the botton of the air extraction channel in order to block the fine dust particles that are not captured.
