Testing the DIYson
A project log for The DIYson, an open source Cyclone vacuum cleaner
Why buying an expensive cyclone vacuum cleaner when you can build yourself one?
madaeonMadaeon 05/15/2019 at 14:531 Comment
It works! There are still a lot of improvements to the design that can be added, as some of you pointed out, but for this first version, I think we are happy how it works. Probably next version I should use a slightly bigger EDF with 1kg thrust instead of 0.5Kg, price is more or less similar.
Battery lasts more or less 20 minutes.
Florian Festi wrote 05/15/2019 at 20:49 point
One part of me wants to write "Cool, now try to vacuum up half a bag of flour!"
But the other part of me is like "Shut up! You want to see this thing getting finished."
