After testing the sensor just a brief summary.
The sensor used is a cheap one purchased in china. Has no brand and is labeled as v 1.2. After a brief inspection the sensor seems to be similar to DFRobot's. A capacitive sensor based on a 555 oscilator to measure the capacitance of the pcb tracks on the sensor area:
Output is measured and confirmed that output is pulled down with a 1M resistor decoupled with a 1uF cap.
0. Sensor range: Range is confirmed with documentation. Dry (air dry): 2.8V / Water (humidity saturation) with tap water: 1,44V. This leave a sensitive range of 1.4V. this range is big enough for a 10-bit ADC.
1. Startup time: When the sensor is powered from a bench power supply at 3.3V the output response require some time to output stable voltage for measurement.
When sensor is submerged in water the response is the following (blue->VCC , yellow-> sensor output):
On dry air the sensor response is similar but it require more more time as the output voltage is higher:
This measurements provide a estimation for the response time of the sensor: 150ms
2. Current drawn: At 3.3V with the sensor floating output the current used by the sensor when power is in line with the specs: 5.3mA.
#include <Arduino.h>
#include <ESP8266WiFi.h>
#include <math.h>
const char *ssid="xxxxx";
const char *pwd="xxxxx";
// Report every
//#define REPORT 10*1000
#define REPORT 2*60*1000
void connectWiFi() {
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
/* Explicitly set the ESP8266 to be a WiFi-client, otherwise, it by default,
would try to act as both a client and an access-point and could cause
network-issues with your other WiFi-devices on your WiFi-network. */
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, pwd);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
digitalWrite(2,1); // Led on initialization
uint32_t order;
void setup() {
pinMode(2,OUTPUT);
digitalWrite(2,0); // Led on initialization
Serial.begin(115200);
// We start by connecting to a WiFi network
connectWiFi();
order=0;
ADC_MODE(ADC_TOUT)
void measure(uint16_t *m,float *std) {
const int n=10;
uint16_t v[n];
int i,u=0;
double std_dev=0.0;
// compute avg
for(i=0;i<n;i++) {
v[i]=analogRead(A0);
u+=v[i];
delay(1);
u=u / n; // average
// compute std dev
for(i=0;i<n;i++) {
std_dev += (v[i]-u) * (v[i]-u);
std_dev = sqrt(std_dev/n); // std_dev
*m=u;
*std=std_dev;
Serial.printf("T:%lu, mean:%d, std dev:%f\n",millis(),u,*std);
uint32_t last_report=0;
void loop() {
uint16_t m;
float std_dev;
if(WiFi.status() != WL_CONNECTED) connectWiFi();
if((millis()-last_report) > REPORT) {
measure(&m,&std_dev);
WiFiClient client;
if(client.connect(IPAddress(192,168,4,1),8266)) {
Serial.print("Sending...");
client.printf("%d,%d,%f",order,m,std_dev);
order++;
client.flush();
delay(500);
client.stop();
Serial.println("sent!");
last_report= millis();
1st I dry the compost in the sun to simulate a dry soil.
2nd I insert the sensor in this dry soil for a while and check the consistency of data.
3rd I water the soil and let the soil dry to check the evolution of the reading until the soil is dry again.
The data is analyzed with simple R commands:
# Load data
no_cover=read.csv("doc/moisture_data_nocover.csv")
# Convert ADC Reading to volts
V <- data$value * ( 3.3 /1024)
png("doc/moisture_nocover.png")
plot(V,col="blue",type="l")
title("Moisture analog value")
dev.off()
png("doc/moisture_stdev_nocover.png")
plot(V,data$stddev,col="red")
title(paste("Mositure stddev mean:",mean(data$stddev)))
dev.off()
Results are the following:
Notes:
- Sensor in Dry Air: Stable near 2.8V.
- Sensor in Dry Soil: After insertion the sensor reacts fast to a 2.5 - 2.4: to dry soil.
- Soil watered and let dry. Response to watering is fast: The value respond slow to drying with a linear trend.
- While drying the sensor show a no linear response near 1.7V jumped to 2.0V and then stabilized around 2.1V. Then the drying continue in more or linear but with a milder slope.
The sensor shows stable readings maximum stddev is 4 units (of 10-bit resolution). Typical Std dev is low to 1 unit. This deviation is probably due to ESP2866 ADC reported by various user as volatile especially when WIFI is connected.
Conclusion
- Sensor performance is sufficient for the project:
- Stable output with little variation on output.
- The sensor response fast to watering events.
- The sensor do not show a pure linear behavior but is suitable for a linear approximation with upper and bottom limits and 3 or 5 linear ranges.
- Sensor consumes 5mA and has a slow response time aground 150ms to have stable reading. Power need to be gated for low power applications with big ADC window.
Next Steps on the sensor:
Repeat the test using a protected sensor. (TODO)
