The State of Both Machines
A project log for (AT) Mega Enigma, a 2560 Pro Mini Enigma Simulator
A minimalist 139x171x50mm Enigma Machine Simulator with working plugboard using an ATmega 2560 Pro Mini and a custom PCB.
arduino-enigmaArduino Enigma 07/28/2019 at 17:070 Comments
Current pictures of the machines:
This is how I ended up doing the Transient Voltage Suppression (TVS) Diodes since the legs were a little wider than the holes on the board.
And a little bit of Yak shaving. This is a programmable tester to make sure the LED display modules are not defective, custom made for this project.
