Changelog
A project log for Compact Strain Wave Gear Actuator(s)
A compact modular design of the strain wave gear for general robotic applications.
Leo VuLeo Vu 05/19/2019 at 03:440 Comments
Version 1.0 used a Deep Grove Ball Bearing instead of a Cross Roller Bearing. I just want to see how good the gear teeth meshed with each other.
This is the tooth template I used. It's a double arc profile for additional rigidity of the flex spline.
*Source: https://www.harmonicdrive.net/technology/harmonicdrive
And the meshing analysis:
*Source: https://www.researchgate.net/publication/290977739_A_harmonic_drive_model_considering_geometry_and_internal_interaction/figures?lo=1
