stp - 4.25 MB - 05/25/2019 at 17:24 |
stp - 5.30 MB - 05/25/2019 at 17:23 |
Standard Tesselated Geometry - 756.53 kB - 05/25/2019 at 17:22 |
Standard Tesselated Geometry - 1.15 MB - 05/25/2019 at 17:22 |
Standard Tesselated Geometry - 308.68 kB - 05/25/2019 at 17:22 |
Standard Tesselated Geometry - 817.66 kB - 05/25/2019 at 17:22 |
Standard Tesselated Geometry - 292.86 kB - 05/25/2019 at 17:22 |
Standard Tesselated Geometry - 255.55 kB - 05/25/2019 at 17:22 |
Standard Tesselated Geometry - 388.17 kB - 05/25/2019 at 17:22 |
Standard Tesselated Geometry - 830.75 kB - 05/25/2019 at 17:21 |
Standard Tesselated Geometry - 775.86 kB - 05/25/2019 at 17:21 |
Standard Tesselated Geometry - 320.59 kB - 05/25/2019 at 17:21 |
Standard Tesselated Geometry - 363.56 kB - 05/25/2019 at 17:21 |
Standard Tesselated Geometry - 305.16 kB - 05/25/2019 at 17:21 |
Standard Tesselated Geometry - 376.64 kB - 05/25/2019 at 17:21 |
Standard Tesselated Geometry - 298.03 kB - 05/25/2019 at 17:21 |
HarmonicDrive1-31.stp.step file for intergration.stp - 18.28 MB - 05/20/2019 at 17:09 |
FlexSpline.stlPrinting with a printer that has X/Y resolution of 100 micron, ideally in nylon or a flexible filament (but not too soft).Standard Tesselated Geometry - 1.53 MB - 05/15/2019 at 18:09 |
Cicular.stlPrinting with a printer that has X/Y resolution of 100 micron, ideally in nylon.Standard Tesselated Geometry - 1.14 MB - 05/15/2019 at 18:08 |
UpperMount.stlPrinting with high infill (>= 80%).Standard Tesselated Geometry - 274.69 kB - 05/15/2019 at 18:08 |
Standard Tesselated Geometry - 298.91 kB - 05/15/2019 at 18:08 |
EllipseDrive.stlPrinting with a printer that has X/Y resolution of 100 micron. Scale down or up a little bit depending on you printer and the fitting on the flex spline.Standard Tesselated Geometry - 590.71 kB - 05/15/2019 at 18:08 |
LowerMount.stlPrinting with high infill (>= 80%).Standard Tesselated Geometry - 363.66 kB - 05/15/2019 at 18:08 |
LowerCircular.stlPrinting with high infill (>= 80%).Standard Tesselated Geometry - 328.70 kB - 05/15/2019 at 18:08 |
HubAdapter635mm.stlAdapter for Nema 23 motor of shaft 6.35 mm.Standard Tesselated Geometry - 330.45 kB - 05/15/2019 at 18:08 |
