DogEars
This is a project to create superhuman hearing for everyone, finally we too can get annoyed by parking sensors and listen to bats!
I've been interested for a while in the unseen and unheard world around us. Theres so much out there that our lowly human senses miss, both visually and audibly. I want to build a set of headphones that can listen to and convert more of the audible spectrum into a range that humans can access.
I propose the device will be able to listen up to around 100KHz, and dynamically transpose this entire range onto the human spectum of around 40Hz to around 17KHz, it will be built into a set of headphones to give stereo sound, allowing the user to basically replace his own ears, and will also allow for the location of a sound source.
Ideally you would be able to hear both "normal" sounds, i.e. speech, music etc, but have transposed on top the ultrasonic range that we can't hear.
I see this also being useful to listen to what your pets can hear, I wonder if there are devices in the home emitting sounds that are irritating to pets, but we are unable to detect them?
Project Specifications....
Built into a set of stereo headphones.
Wide Range microphone in each headphone 'can', orientated with the ear canal.
Digital processing to allow frequencies to be shifted, compressed and analysed.
As low processing delay as possible.
Battery powered.
Connectivity with smartphone to allow settings to be changed, maybe to account for hearing loss, desired range to be captured etc.
"Pet" Settings, to give the user the experience of listening to the sounds their favourite pet can hear, e.g. Dog, Cat, Ferret, Tyrannosaurus Rex.
A large part of this project will be the Signal Processing software. The device needs to sample the ambient sounds, use FFTs to decipher the spectrum, then decide how to recreate the signal in a range that people can hear.  This isn't something I've played around with before, so should be an interesting learning experience.
I've also never done any smartphone programming, so this will also be a challenge.
There are already a range of bat detectors on the market, most of which use hetrodyne mixing to shift a portion of the spectrum, but these are generally handheld devices and most don't access the wider range of spectrum.
This is another step towards augmented humans, I forsee a future where devices like this could be implanted directly into people, giving permanent superhuman senses.  Another future device would be eye augmentation, I would love to be able to see into other spectrums.  As a RF engineer working in Broadcast, my dream would be to have a pair of glasses that could see RF being emitted.
Something I want to investigate with it is whether humans can be trained to use echolocation. I'm thinking the microphones can have a 3d printed cover to replicate the directionality of human ears, then with the addition of a couple of ultrasonic transmitters, it may be possible for people to use this to navigate in a dark environment.  That would be amazing to experience!
Another thought I had recently is to do a second version that could listen to RF... Basically an aural spectrum analyser, It would be amazing to listen to a bluetooth transmitter switch on for example, or in my day job as an Broadcast Engineer, it would be invaluable to listen for interference, or to see whether transmitters were working.  I imagine with experience you would be able to distinguish power levels, and maybe even tell whether it was transmitting correctly. We occasionally have problems where things like PAs fail , immediately you would hear a reduced level....
  • Soggy Saturday Syndrome
    FrazzledBadger07/19/2014 at 11:53 0 comments
    Well, rain has stopped me from working on my camping kitchen project today, so I'll do another DogEars update.
    I've chosen my FPGA, I've gone for a Spartan 6 LX9 chip, it seems to be able to fit all the FFT goodness I need with plenty of space left over for any extra magic I need. Big advantages are its a 144 pin TQFP, which if loverly compared to a BGA, so will be simpler to design.  Plus its only £15 from Farnell, which isn't too bad for a chip of this calibre.
    I've initially decided to use SPI Flash to store the configuration files, but am planning on having it switchable, so the microprocessor can also program the FPGA.
    I'm currently working through my main pcb design, I want to basically make it a useful generic pcb, that can be put into a breadboard. I'm trying not to go too mad with it, feature creep is a swine...
    So far I'm planning on including:
    2 ADCs in and 2 DACs out for the audio conversion, these could be used in the future for any signal conversion, eg sensors etc.  I've chosen the Touchstone Semiconductor TS7003 for the ADCs as they are 12bit, 300KSPS and only cost £1.46 each. For the DACs, I went a Wolfson WM8759 Stereo Headphone Amplifier, these are 24bit, 192KSPS and only cost £1.07 each.  The Wolfson takes a variety of digital audio signals, for example I2S or AES.  The FPGA will have to have this interface coded into it.
    Blutooth Interface, which will basically be a header and components for one of the cheap blutooth boards from eBay.
    Ultrasound Transmitter interface
    A Microprocessor with SD card interface because it may be useful ,plus I'd like to play around with updating the alll the firmware from SD card at some point. This is something I keep meaning to play around with as it will be really useful for other applications.
    IO Ports, these will be breadboard pin compatible, I will try to externalise as many pins as possible, you can never have too much IO!
    A Highspeed connector for daughterboards. I was getting excited about including things like ethernet, usb, maybe some sort of LCD interface, but this makes the project way more complex than it needs to be, so I decided to put a highspeed connector on the PCB, to allow me to design the other toys on daughteboards at a later date, subject to whatever requirements I need.  This is the beauty with having access to such cheap boards from places like Seeed or OshPark, a few years ago these designs would have been too expensive for me to have had made.
    In other news, I've stepped into the scary world of GitHub, I'm planning on totally opening up the project, and making schematics, code and gerbers accessible. Check it out, the link is underneath my pictures.
    I've also had a quick look at Android programming, with the view to creating an app for this, not sure how complex this will be, its not something I've tried before, but as my brother says, "How hard can it be?".......
    If it proves him wrong, I may do a prototype just using python scripting on my phone initially.
  • Quick Update!
    FrazzledBadger07/15/2014 at 05:47 1 comment
    Just a quick update, I've been thinking about how to do the main FFT transformations, I need to do 2 FFT and 2 Inverse FFT calculations at the same time. To me, this immediately shouts FPGA, so I am currently researching the best chip to use. I'm thinking I could also produce a small tutorial on how to use FPGAs, including designing them into a circuit, board payout and soldering the little swine down.. BGAs.. urgh..
    I'm also thinking it would be nifty to produce a board with FPGA and associated gubbins on it that has pinouts so it can be breadboarded or have headers attached. This would be great for future projects.
    So far I think the pcb should contain:
    FPGA(obviously..)
    Power Supplies, it would be great to run it off a single 5v supply
    a couple of ADC and DAC convertors
    Program Flash
    RAM
    There is another project entered into the Hackaday Prize which is similar to DogEars, so to add a unique twist, I want to add a couple of ultrasonic transmitters, and investigate whether humans can be trained to use echolocation to navigate a dark environment.  This would be a fascinating experiment and would have positive benefits, for example for blind/partially sighted people.
    I want to investigate human ears, specifically the angle of hearing created by the shape of the ear, this could then be replicated with a 3d printed doodad to give the most accurate replication.  This would then allow the wearer to sense the direction of the sounds.
  • MEMs Microphone PCB Design
    FrazzledBadger07/01/2014 at 19:29 4 comments
    So I've been beavering away on designing the first PCB for this project, a MEMs microphone and preamplifier board, this pcb will hopefully fit into each headphone, so I've designed it to be reasonably small.  I'm sure I could of gone smaller with 0402 components and a smaller OpAmp, but I didnt feel the need. As it is, the PCB measures 17mm x 22mm.
    I've used the same opamp design as for my test board, it seemed to be a reasonable circuit, and has scope to play with the gains by changing out components. The only difference is I've added the MEMs microphone, a LDO Regulator and a 3 pin header.
    Interestingly the MEMs datasheet specifies no Catagory 2 Dielectrics in the capacitors, this wasn't a term I'd heard before, but after a quick Googlify, I found out it meant I couldn't use X7R or X5R dielectrics, so C1 is a C0G and C2 is a Tantalum Electrolytic, as I could only find Class 2s in the 10uF size. The footprint is 1206 though, so this gives me plenty of scope to chop and change.
    After an afternoon of laying out, I ended up with this:
    I'm pleased with it, its a reasonably compact design without going crazy, M1 is the MEMs microphone, the aperture is underneath, so I had to design in a large via in the board.  Should be interesting to solder.....
    I'm going to design the main board next and then send both off to Seeed Studios, to get the advantage on postage.
  • Electret and Amplifier Test Design
    FrazzledBadger06/28/2014 at 21:57 0 comments
    The first step of this project is to build a Electret Element test board.  I've chosen the Panasonic WM-61A element for this.  A basic circuit to power it is thus:
    Here, the resistor is to restrict current flow and seperate the Vcc line from the audio signal, and the capacitor is used to AC couple the signal.
    This audio is the fed into an opamp, I'll use NE5534 for this. Its only for test purposes, so doesnt have to be too fancy, just a general low noise one will be fine. The final schematic of the element and preamplifier look like this:
  • Microphone Selection
    FrazzledBadger06/28/2014 at 19:42 0 comments
    So theres essentially 4 types of microphones, piezo transducers, electret, electrostatic and MEMs.
    Piezo Transducers.
         These are generally flat discs that uses a piezoelectric effect, essentially when it is distorted by sound waves, it generates a small amount of electricity.  The disadvantage with these is they are generally only used for a narrow frequency range, eg around 40kHz.
    Electret Elements.
        These are the generic microphone element, used in everything from camera microphones to toys.  Cheap and readily available, they are rated for around 20 to 20kHz, but some do respond well to up to 100KHz.  A popular one for bat detection is the Panasonic WM-61A,
    http://www.panasonic.com/industrial/components/pdf/em06_wm61_a_b_dne.pdf.
      The only problem with this is there is no hard data on the response above 20kHz.
    Electrostatic Elements.
      These are essentially capacitors where the sound vibrations cause a change in the distance between the plates. They have a good range, up to 200kHz, but need a high voltage, around 200V to use.  This isn't something I want to strap to my head....
    MEMs Elements.
       These are the new kids, small surface mount packages with the element etched directly onto the silicon wafer.  There are only a few that have their high frequency response documented, one such example is SPU0410LR5H from Knowles.
    http://www.knowles.com/eng/Products/Sensors/Ultrasonic
    This has the the response described up to 80kHz, and is also a very small package, being only around 3mm2, and only 1.1mm high.
    Conclusions.
      Well, all things considered I think I will take a 2 pronged approach to this. I will design my PCBs to use the Knowles MEMs elements, but for testing and development purposes I will buy a couple of Panasonic electret elements, this means I can develop the system whilst the PCBs are being made.
  • Initial Research
    FrazzledBadger06/28/2014 at 18:05 0 comments
    Ok, this project will be split into multiple parts (obviously..). I envision these being:
    Microphone selection.
    Analogue audio amplifer and ADC design.
    DAC design and headphone amplifier.
    Processor/FPGA Selection.
    Power Supply selection/design.
    Bluetooth Integration.
    Smartphone programming.
    DSP research and programming.
    Prototype and test.
    Assembly.
View all 6 project logs
aronharry7 wrote 10/09/2023 at 21:12 point
Your idea of developing headphones that can expand the audible spectrum to include ultrasonic frequencies is fascinating and has potential applications in various fields, including audio enhancement, pet communication, and even certain scientific research areas. However, there are several technical and practical challenges you'd need to address in order to bring this concept to life:
Ultrasonic Microphone Technology: Developing sensitive ultrasonic microphones capable of capturing sounds in the 100kHz range accurately can be a complex engineering task. You'd need specialized sensors that can pick up such high-frequency vibrations.
Frequency Transposition: Transposing ultrasonic frequencies down to the audible range would require a robust signal processing system. This includes advanced digital signal processing (DSP) algorithms to convert and overlay ultrasonic sounds onto the audible spectrum.
Audio Quality: Maintaining audio quality and fidelity while transposing such a wide frequency range can be challenging. Ensuring that the transposed sounds are clear and not distorted is crucial for user experience.
Spatial Awareness: Achieving spatial awareness and location accuracy for sound sources is another complex aspect. You'd likely need advanced spatial audio processing algorithms and multiple microphones to determine the direction of ultrasonic sources.
Human Perception: While it's theoretically possible to transpose ultrasonic sounds into the audible range, it's important to consider how the human brain would interpret and integrate these additional sounds. It might require some adaptation to avoid overwhelming the listener.
Safety Considerations: Ultrasonic frequencies, especially at high levels, can potentially be harmful to both humans and animals. Safety precautions would need to be implemented to protect users and their pets from exposure to excessive ultrasound.
Market Viability: Assessing the market demand for such headphones is crucial. While there are potential applications, you'd need to determine if there's a substantial audience willing to invest in this technology.
Regulatory Compliance: Depending on your location and target market, there may be regulatory requirements and safety standards to meet when developing and selling such a device.
Overall, your concept is intriguing and could have a range of applications beyond just personal audio. However, it's a complex project that would require a multidisciplinary team of engineers, signal processing experts, and potentially biologists or veterinarians to ensure it's both feasible and safe. Conducting thorough research and feasibility studies would be an essential first step in bringing this idea to fruition.
https://magixshears.com/
aisha.taric34 wrote 08/14/2023 at 22:48 point
This is perfect. Our community at https://petsais.com/ liked it so very much. We will recommend this to people in our blog posts.
aisha.taric34 wrote 08/14/2023 at 22:47 point
This is very perfect and good. Our community at https://petsais.com/ liked it so much. We'll recommend this to people in our blogs.
FrazzledBadger wrote 07/07/2014 at 08:15 point
Thanks for the post Adam, I never saw that project, I'll have a look to see how I can differentiate mine..
Adam Fabio wrote 07/07/2014 at 06:01 point
Thanks for entering The Hackaday Prize! Looks like we have a couple of audio transposition projects entered. http://hackaday.io/project/1620 is similar - though not exactly the same as what you're going for! It will be great to see how both your projects come out.
Good luck - and keep the updates rolling in!
