FFC cable, retention pegs, top panels
A project log for USB-C Gamepad Phone Case
A USB HID gamepad integrated into a phone case.
MaaveMaave 07/21/2019 at 04:240 Comments
I think I'm ready to order!
I swapped the solderable headers with a FFC connector. This is a small flat cable that's common, generic, and cheap. I settled on the FH12-8S-0.5SH(55) which is a 0.5mm pitch 8-pin cable. This connector had a small enough footprint that I could fit it in the existing 2sq inch outline.
-Power and ground tracks have been made thicker. I set this in the net classes which the autorouter uses.
-Retention pegs and cutouts have been added to keep the PCB in place.
-Modeled top panels.
One more review then 'll order the PCB and parts. I have lots of ideas for the future but I want a working unit in my hands first.
