Menu Test complete
A project log for DIY SamplePad Controller (MkI)
A unit to allow sample audio files be triggered and played by Roland drum pads
craig-hissettCraig Hissett 06/06/2019 at 23:491 Comment
Apologies for the slow updates everyone, I've been having a bit of a difficult time getting stick into projects at the moment.
Today I have tested the setup for menu, using a Wemos Mega + WIFI board, i2c LCD, some push buttons and the dfrobot mp3player unit.
The menu is simple, butndoes all itllnever need to do. Clicking the rotary encoder button selects either Bank or Volume on the menu  and rotating it will adjust the relevant variable.
Next I'd like to solder up a small board with the jack sockets in it, alongside the screen and encoder. This'll keep the in case set up nice and neat.
Craig Hissett wrote 06/15/2019 at 22:14 point
Encoder has arrived, and works great.
Some filtering needs applying to the interrupt code as well as restricting the Reachable values for volume and banks, but other than that the GUI is working well.
