Even MOS/CSG was re-using layouts!
A project log for MockA65xx - Universal 6502/85xx CPU replacement
Project to reverse-engineer and create edge-level exact replacements for major MOS6502-derivatives and also other MOS/CSG chips!
androSIDandroSID 07/09/2019 at 15:060 Comments
When starting the project I actually used die shots which were much worse
than the ones I use now (for other projects):
MOS8500R4 (aka 6510) vs. MOS8501R4
Although picture quality is quite embarrassing I could get use them because of
their similarity. That means: MOS/CSG really re-used chip masks which can
clearly be seen here.
