All the pieces
A project log for 3D Printed Robot Joint with Active Compliance
A general purpose robot joint using a cycloidal gearbox and an ODrive modified to support active compliance
tim-wilkinsonTim Wilkinson 06/19/2019 at 20:340 Comments
To assemble one robot joint you'll need for following printed parts:
Almost every part is unique, except for the two outer supports (those keyhole shaped parts with the 8 holes in a circle). You will also need a few extra pieces of hardware:
These are (with Amazon links):
You also need a motor. I'm using these:
