Reworking embedded computer software
A project log for Cosmic Array
An array of cosmic ray detectors across a landscape that demonstrates in light and sound how cosmic rays are constantly all around us.
paul-schulzPaul Schulz 06/23/2018 at 01:030 Comments
In order to make each detector easier to manage for end users we are looking into alternatives to Emdebian.
This isn't an issue with the operation of the detector. Once a system has been setup, the Operating System (OS) can be changed as easily as rebooting and swapping MicroSD cards.
One alternative OS is OpenWrt/LEDE, which has recently merge again after a fork. One benefit of OpenWrt/LEDE is that it comes with a web based configuration tool - Luci. As well as a 'registry' style of configuration management (in /etc/config, and managed via the 'uci' tool), the web interface provides an easy way of managing the network connectivity and getting to device onto a network.
With the Raspberry Pi Zero W running Openwrt, there are instructions available to allow network connectivity via USB to a connected PC.
Another useful piece of the puzzle is the build environment that comes with OpenWrt/LEDE. It should be possible to build an ipkg with our cosmic-array software which will improve development, deployment and version control. What this space.
