Started Soldering Both Machines
A project log for Nano Z30 a Numbers Only Enigma Machine Simulator
A minimalist 130x74mm Numbers Only Enigma Z30 Machine Simulator using an ATMega 328 powered Arduino Nano and a custom PCB
arduino-enigmaArduino Enigma 06/07/2019 at 11:050 Comments
Started to solder both enigmas.
What's wrong with this picture?
The answer and more pictures here:
https://hackaday.io/project/165559-at-mega-enigma-a-2560-pro-mini-enigma-simulator/log/164379-arduinos-and-keyboards-soldered
