Putting batteries inside the enclosure
A project log for Nano Z30 a Numbers Only Enigma Machine Simulator
A minimalist 130x74mm Numbers Only Enigma Z30 Machine Simulator using an ATMega 328 powered Arduino Nano and a custom PCB
arduino-enigmaArduino Enigma 01/14/2020 at 05:180 Comments
To put batteries inside a laser cut enclosure, one has to think in 3D using 2D:
The pictures in this article will show how:
https://arduinoenigma.blogspot.com/2020/01/how-to-put-battery-compartment-inside.html
And now that there is a built in battery compartment, then the question of how long will it run on batteries becomes more important.
The following article shows a method of measuring run-time by writing timing checkpoints to EEPROM, no external components needed.
https://arduinoenigma.blogspot.com/2020/01/measuring-battery-run-time-by-writing.html
