Moved source to Github ...
A project log for rPi bare metal vGuitar rig
An attempt to create a working live guitar rig that includes effects, midi synthesizers, loopers, controllers, and user feedback systems.
patrickPatrick 09/05/2019 at 00:260 Comments
2019-09-04
I have moved the source code for my modifications of Circle to Github.
This is after updating, today, to the latest Circle source which supports the rPi 4.
I re-forked the Circle source and re-applied my changes for better upwards compatibility with future releases by rsta.
There are two Github repositories:
https://github.com/phorton1/circle contains my Fork of Circle, with as few changes as I could make to get my stuff to compile and work.
You should be able to clone and build the above completely separately from any of my specific changes, below.
https://github.com/phorton1/circle-prh contains my Additions to Circle.  This repository gets cloned to a folder called "_prh" within the above repository.
This change minimizes the amount of work I have to do as rsta provides new updates to Circle.
The previous repository at Bitbucktet has been eliminated.
- Patrick
