New boards! They don't work!
A project log for Internet Connected Boot Dryer
Modifying a Boot Dryer to be controllable via the internet!
markmark 06/14/2019 at 01:020 Comments
Welp
got new boards that don't work
  1. Switch footprints are wrong. The two pins the switch contacts are wired to be across are actually common with each other.
  2. The relay footprints are wrong. The way it's wired has the switch where the coil is and vice versa. My fuckup on the schematic symbol.
  3. After bodging the relay problem, the 3.3V regulator drops out for some reason, only giving like 2V
  4. Also the auto-reset circuitry doesn't work.
Time to test and redesign, wheeeee
