smart_boot_revd.pdfProject schematicAdobe Portable Document Format - 59.98 kB - 06/23/2019 at 18:35 |
flows.jsonThe node red flows that work with MQTT to control the dryerJavaScript Object Notation (JSON) - 25.34 kB - 06/15/2019 at 00:08 |
smart_boot.csvBOMms-excel - 567.00 bytes - 06/15/2019 at 00:04 |
config.example.jsonA config.json file that needs to be put into SPIFFS for the ESP32 to read and configure everything with. Change all values to your relevant information.JavaScript Object Notation (JSON) - 286.00 bytes - 06/14/2019 at 23:58 |
smart_boot_esp32.inoThe Arduino code for the ESP32- 16.11 kB - 06/14/2019 at 23:58 |
