Hacking a Prototype
You know the moment when you're designing or making something, the one you have is just fine how it is, but then you decide you want to try make it even more "perfect" and then end up messing the whole thing up? Well, this is precisely how an "overachiever's" error on a Null Modular case prototype became the perfect fit for hacking to embed the LED channel in the light feature for the F(n) series.
F(n) Case vs +1 (embedded LED Channel Case Prototype)
Thankfully, I have a tendency to hoard mistakes! The following illustrates the process of adjusting the miscut side panels.
