Update
A project log for Prototype SCARA Mark II
My second SCARA project. This time it will be twice as big and geared.
agp.cooperagp.cooper 06/07/2019 at 02:380 Comments
Update
While I have been waiting for the end-mills, drill bits, 6mm acrylic sheets and acrylic glue to arrive, I have been working on other projects. The orders have arrived and I have finished the other projects.
Where was I?
Here is may last plan for 6 mm thick acrylic:
My last Section:
May last layout for my CNC mill:
The layout shows two slew bearings while the section has three bearings. The prototype bearing was quite good so I don't think I need the second bearing on the tower.
I also have not really considered the tower and the base board.
CNC Mill Parameters
Base Board
The working envelop needs to be 2:1, the key assumptions are:
I calculated the following:
Dy 173.735 Working Area Height
Dx 347.469 Working Area Width
L1 200.000 Arm 1 Length
L2 150.000 Arm 2 Length
A1Min -6.143 Calculated Motor 1 Range (Min)
A1Max 115.600 Calculated Motor 1 Range (Max)
A2Min 10.000 Motor 2 Range (Set Min)
A2Max 140.000 Motor 2 Range (Set Max)
Ox -173.735 Bottom Left Corner
Oy 128.598 Bottom Left Corner
Here is the base board layout including the tower location:
It fits on a 400 mm x 400 mm board. This layout has a effectively wider feet spacing.
The normal layout is still 400 mm x 400 mm:
Tower Design
TBC ...
Limit Switches
TBC ...
AlanX
