1Install QEMU
open QEMU download page and download it. 32-bit or 64-bit depends on your windows version.
Install it and make sure you added it to your windows PATH ENV variable.
2Download Alpine Linux ISO
open Alpine Linux download page and download the extended image.
3create folder for your docker files
create a specific folder (eg : c:/docker) to store all of your docker files.
4create QCOW2 image
use this command to create qcow image
qemu-img create -f qcow2 alpine.qcow2 16G
5boot QEMU
use this command to run QEMU. make sure you change :
- architecture (32-bit / 64-bit)
- alpine image
- alpine.qcow2
qemu-system-x86_64.exe -cdrom alpine-extended-3.8.2-x86_64.iso -m 2048 .\alpine.qcow2 -net user,hostfwd=tcp::2222-:22 -net nic
6Install Alpine Linux
log in with username "root" . then , install Alpine Linux by running command "setup-alpine" . just follow the instructions.
you can refer to Alpine Linux Installation guide
tips : when asked about about sys, data, etc , choose "sys" because it's the traditional hard disk install.
7Install docker
install docker with the command below. make sure "Community" Repository were enabled before running the command.
apk add docker rc-update add docker boot service docker start
To install docker compose , follow the command below . if "pip install docker-compose" failed, upgrade your pip. the update command is shown as a warning/yellow message.
apk add py-pip apk add python-dev libffi-dev openssl-dev gcc libc-dev make pip install docker-compose
you can refer to Alpine Linux installing Docker Guide
