The Keys
A project log for Recreating the Jupiter Ace
Recreation of the 'Fastest computer in the Universe' that runs FORTH.
cees-meijerCees Meijer 06/09/2019 at 10:310 Comments
As the original rubber keyboard is not an option, I decided to use the standard 6x6 mini tactile switches. Which can be bought for around €5 per 100 in China.
Mini tactile switches
Mini tactile switches 6x6x5mm
 I already tried as a proof of concept to create the key-caps by printing them in white, spray painting black and then scrape off the paint from the cap-text.
3D Printed key
3D Printed key-cap, prototype
Which works out really nice. Next the caps needed to be modelled so he fit exactly on top of the switch. This took several tries as the fitting needs to be tight but not too tight and so it comes down to a tolerance of +/- 0.1 mm. But in the end this works fine. The caps stay in place, the key-press has a nice tactile feedback and it looks a lot like the original.
Key caps
Assembling the key-caps and the mini-switch
