Portable MP3 Player
This player can be worn on the wrist like a bracelet.
mszmsz
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
This project is based on a powerful and energy-efficient STM32 microcontroller. The microcontroller contains a Cortex-M4 core with floating point unit running at 180 MHz. Serial audio bus has been connected to an Audio-DAC. TS4657 is a stereo DAC that integrates a high-performance audio line driver capable of generating a 2.2 Vrms output level from a single supply. MPs files are stored on a memory card. OLED display is used to show information about track and to select MP3 file. User controls the player using a simple keyboard with a few buttons (PLAY / STOP / PREV / NEXT / MENU / SELECT). Components: Flex PCB STM32F427 Microcontroller TS4657IQT stereo DAC Memory card slot Micro-USB connector for data transmission Mini jack connector SSD1306 OLED 128x32 Display with I2C interface Keyboard Battery
