Assembly Cones of Shame
A project log for PCB Decahedron
You can get 10 pcbs from most manufactures for cheap if they are under 100mm on each side. Let's make some shapes.
ian-shannon-weberIan Shannon Weber 08/09/2019 at 00:030 Comments
The reason I was using the helping hand to solder the boards together was because I was able to make a jig to help me solder the boards together. This has made it apparent that I need to review my 3 dimensional geometry.
3d printed cones in an effort to solder the sculpture boards
