CNC in a box
A simple CNC, storable and flexible enough to handle few use cases
Requirements:
1. Compact: Needs to fit into the largest of IKEA plastic box.
2.Can be installed in a few minutes, which means the electronic needs to be neatly packed and have clear connectors.
3. Moving gantry, so it can mill the support it standing on (eg. a table or any large board)
4. Able to handle modules (laser, spindle, router trimmer)
When I started to look at commercial desktop size CNC, it seemed there were two kinds of models: the cheap ones from China at $300 (Banggood, Aliexpress, etc) and the other ones starting at $1200.
At first I thought I would buy a cheap one and upgrade it, however when looking a bit closer some issues appeared:
  1. The spindle will need to be replaced, and that would cost $100 + $50 for a new power supply
  2. The stepper motors looks like the lower end of the Nema 17 which might be a bit weak for machining aluminium
  3. The axis are using a lead screw and some rods which looks bulky and not sturdy enough
  4. The connection plates between the axis are 3d printed and I have some doubt on the sturdiness, squareness and accuracy of the assembly.
  5. They have a moving bed which means the footprint of the CNC is quite large compared to the working area.
It might be good for engraving PCBs but not for what I want to do.
When looking at other models, the standard Shapeoko could have been a fit but the price is a tad too high and the footprint a tad too big.
So I decided to build my own, which is more fun. I will be picking better quality components than the cheap ones, customizing the size and going for a moving gantry. I also live in an apartment, and need the CNC to be transportable and storable easily.
I'm trying to keep it as simple as possible while making sure I could increase the size one day.
I will try to make a short video explaining which components I picked and what's the reason behind. I will also publish the drawings of the fixture between the axis so that anyone can reproduce that, no matter the size of the CNC.
Below is the drawing with the dimension of the plates to be cut out and assemble to join the different axis. Please note those are not the final dimensions as I'm fine tuning them.
Here's the first assembly of X axis and connectors to Y axis
The CNC in a box, as advertised
The front end of the enclosure
The back with the connectors
Adobe Portable Document Format - 123.32 kB - 06/26/2019 at 06:38
Preview
Download
View all 25 components
  • Enclosure - Final Part
    vincentmakes07/25/2019 at 07:18 0 comments
    The enclosure is now completed: I added the connectors for the spindle, motors and power supply in the back and wired everything inside, including the ATX fan.
    Here's few pictures
  • Enclosure - Part 3
    vincentmakes07/22/2019 at 07:28 0 comments
    I made good progress on the wiring: the front is completed, and the power has been connected to the back.
    As you can see in the pictures below, the voltage of the two power supplies are displayed on one panel and the lever allows to switch between the two while a potentiometer allows to adjust the voltage of the one for the spindle/laser.
    The power supply for the motor is not meant to change and while it can be adjusted it is not necessary to have an easy access to do it.
  • Enclosure - Part 2
    vincentmakes07/19/2019 at 07:07 0 comments
    I finalized the front of the enclosure and replaced or added a few knobs and features as below.
    I'm still thinking about what I can do with this power button on the right. It triggers a pulse switch, so maybe I can make an emergency stop or a hold button ?
    Next steps are to finalize the wiring of those features, then I will move to the back of the case to add the connectors for the motors/spindle/lasers and the power supply outlet.
  • Enclosure
    vincentmakes07/10/2019 at 08:00 0 comments
    I got a cheap mini ATX case and turned it into an enclosure for all the electronics.
    The front also has a few usb port and buttons. I will keep one USB port for the Arduino, insert a voltmeter for one of the power supply and add 2 potentiometer knob to adjust the voltage and the speed of the spindle. One of the usb port will be removed to insert the spindle switch. The back will have the two power supply outlet with a switch as well as 5 outlets for the motors and the spindle.
    The main fan of the case will be wired to the +10V of the spindle controller.
    Here's a first snapshot with the components before wiring
  • It Works !
    vincentmakes07/08/2019 at 06:29 0 comments
    Good progress were made over the weekend:
    After replacing the Arduino it simply worked. Below is an engraving test for Muffin, our hamster, who is absolutely thrilled about this new sign as you can see.
    I did further tests with harder material such as acrylic but clearly the Z axis shows its limit and there was too much bending. I will replace that one with something stronger.
    The next steps are also to tidy up everything and put the power supplies and the controller in an enclosure
  • First tests
    vincentmakes07/04/2019 at 09:07 0 comments
    Time to put the machine to the test. I tried to engrave our hamster's name on pine wood with limited success.
    1. I'm getting a lot of error when using the knock off Arduino Uno. It fails randomly and I wasn't able to fully engrave the text. it seems that some instructions are not sent correctly or completely to the device. I had the same result on a dry run (no CNC shield attached)
    2.When using an old original Arduino, it works without error on a dry run however when connecting everything the Y axis doesn't move physically despite having the same parameter in the firmware. Bummer. Not sure if I damaged this board in a previous project so just to be sure I will try with a brand new one again.
    If all fails, I will try to reduce the baud rate or check if I need to uninstall the driver I had to install for the knock off Arduino.
    On the few letters I manage to engrave, it does the job however the Z axis has a lot of flex and that shows so I will replace that one with something more sturdy (similar to the other axis)
  • Frame Assembly Part 3
    vincentmakes06/29/2019 at 20:05 0 comments
    I basically finished the assembly, although there are still some hard points that needs to be solved. The pieces for jointing are square but I missed my measurements in some area by a couple of mm. Making bigger bores for the screws seemed to make it up for the accuracy and this is going the right way overall.
    However the Z-axis ready made I bought seems to have a bit of flex in the X direction. I'll see what's the consequence of that when milling and can fix it by attaching the bottom of the sub assembly to the frame with a custom bracket.
    And I added a fan on top of the CNC Shield, self powered by the 5V from the board. This is plenty enough to cool those drivers which are regularly burning my fingers
  • Frame Assembly Part 2
    vincentmakes06/19/2019 at 07:09 0 comments
    I have mounted the motors on the X axis using the Openbuild flat brackets as they seem to fit quite well. I have also started to put together the Y axis but will have to do some adjustment and make new spacers underneath the KP08 bearings in order to accommodate to the motor height. I will have brackets made of plywood to mount the other side of those bearing as well as the motor bracket.
    Here's a picture of the Y axis in progress
  • Frame Assembly Part 1
    vincentmakes06/17/2019 at 07:18 0 comments
    I started to put together the frame. The between hole distance of the bearings KP08 doesn't match the rails of the aluminium profile. However, those bearing have also a ball joint in order to compensate for any misalignement so I took advantage of it and 'tilted' the bearing till it was matching the rails. The result looks a bit strange and crooked but it looks like it will work
  • Initial tests + setup of the stepper motors and CNC Shield
    vincentmakes06/11/2019 at 08:47 0 comments
    I received the controller as well as the stepper motor and did some tests with them.
    CNC Shield v3.0+Arduino Knock Off from Banggood
    I used the CNC shield v3.0 from Banggood as well as some DRV8825 stepper drivers. I'm using GRBL v1.1 for the firmware which seems to work well so far. I'm using a Macbook and a knock off of an Arduino Uno. The knock off keeps crashing my laptop and I thought it was due to a shortcut but is in fact a well known issue that only requires to install a driver.
     I have ordered in parallel an official and recent CNC shield from Protoneer. The main reason is the new board has some capacitors integrated to filter any noise which is nice because the steppers are generating a lot of it.
    Precautions
    There are few precautions to take with the setup that I learned after burning one of the driver:
    1. There's a trimpot on the driver board that needs to be adjusted before pluging in the stepper motors.
    2. Do not plug/unplug the steppers or the driver while the power is on
    As a precaution I have set the Vref (between the GND and the trimpot) at 800mV which means the current should be 1.6A. The steppers are rated at 2A but I will start at a lower value given the drivers are heating up a lot already.
    Configuring GRBL:
    The steps/mm (parameters $100,$101,$102) are calculated as following
    The Nema 17 that I got are rated at 1.8deg/step which means there is 360/1.8= 200steps /revolution by default.
    I have also setup the microstep of the driver to be at 1/8 which means the output is now 200*8=1600 steps/revolution
    When I rotate the lead screw by 1 turn, it moves by 8mm which means  the steps/mm is: 1600 steps/revolution / 8mm/revolution= 200steps/mm
    This is enough to start with and I will do some more accurate measurement when everything is in place in order to calibrate the system.
View all 11 project logs
