It Works !
A project log for CNC in a box
A simple CNC, storable and flexible enough to handle few use cases
vincentmakesvincentmakes 07/08/2019 at 06:290 Comments
Good progress were made over the weekend:
After replacing the Arduino it simply worked. Below is an engraving test for Muffin, our hamster, who is absolutely thrilled about this new sign as you can see.
I did further tests with harder material such as acrylic but clearly the Z axis shows its limit and there was too much bending. I will replace that one with something stronger.
The next steps are also to tidy up everything and put the power supplies and the controller in an enclosure
