Mechanical Assembly of the B-Sample nearly completed. Welded the Frame, tested different configurations for the lever arm, tested the Rod-Plunger and inserted coupling for the mold.
Check out MIRO and our Instagram Account for more details. https://miro.com/app/board/o9J_kpTbPsU=/
DevLab.nrw
