The first parts
A project log for P.C.M. Mask
How To Hack Your Brain :). The main Idea is to control different led pattern with my pulse while listening to relaxing music.
alain-mauerAlain Mauer 05/30/2019 at 19:170 Comments
I used a laser cutter to build the first parts of the mask. So I can check if the Led's will fit and to see, what I will see in the mask.
