Most useless application? LED blinking by 3A5
A project log for Vacuum tube game in 21st century
Playing vacuum tube is not so difficult as expected. Let's play great heritage of human being by modern technology!
kodera2tkodera2t 06/08/2019 at 12:172 Comments
I like 3A5 so much, for its mellow and brilliant sound through triode. But this time, the application may be most useless one. It's LED blinking.
It's blinking period can be determined by C-R discharging time constant. Indeed, we can simply regard Grid-Gate, Plate-Drain, and Kathode(3A5 is direct heated tube so it is GND of heater)-Source between vacuum tube and FET. The big difference is heater power requirement and high voltage requirement. Actually "gm" is common in both FET and vacuum tube!
kodera2t wrote 06/09/2019 at 10:03 point
Now added in the new project log. Thank you!
Ken Yap wrote 06/09/2019 at 01:32 point
Can we see the circuit diagram? Is it an astable using two triodes with cross-coupled capacitors?
