printhead wiring + Bowden tube
A project log for X printer - portable
Portable CoreXY 3D printer (foldable)
Malte SchraderMalte Schrader 09/05/2019 at 14:380 Comments
The final printhead is mounted.
The wiring of the printhead is pretty tight and very close (too close ?)  to the heat block, but the heat block has a silicone sock, so I hope everything will work fine.
The Bowden tube is foldable mounted to the printhead for maximum portability.
