1/30/2021 - bringing up boards notes
- Sch/brd name Wedding 5
- Using Atmega328PB
- AAA battery footprint (not AA as mentioned before) still not quite right
- Programming over ISP works, power supply works
- Programming over FTDI/ UART works, I found this to be finicky, see next log for details
- Blinktest.ino works with all LEDs
- LEDs have 124 ohm resistors, could probably go to 150 ohm
- CS has a 10k pullup
- Trick: open -n -a EAGLE in terminal to see more than one instance
- TODO:
- test internal oscillator (8 MHz)
- test cap touch sensor
Testing radios today:
Name/ Port/ Atmega pin/ Arduino IDE pin
- CS / PB2/ 14/ 10
- SDO (MOSI0)/ PB3 / 15/ 11
- SDIO (MISO0)/ PB4 / 16/ 12
- SCK0/ PB5/ 17 / 13
- RADIO RESET/ E1/ 6/ 24
- INT/ PD2/ 32/ 2
BATTERY LIFE
- ADC, 10 BITS, GND REF, 0 - VCC RANGE
- ADC HAS SEPARATE POWER SUPPLY AVCC.
- AVCC must not differ more than ±0.3V from VCC.
- Needs capacitor added to pad (oops)
- BATTERY READ/ ADC6/E2/ 19/ A6
- V(out) = V(in)*(R2/(R1+R2)) where max Vin is 1.5 V (AAA battery), Vout is 1 V
pin voltage mV = (ADC value *system voltage mV) / max ADC value // 1 V = (ADC value * 3.3V)/ 1024 // Max ADC = 310
PINOUTS
// digitalWrite(0) //--> D0
// digitalWrite(1) //--> D1
// digitalWrite(2) //--> D2
// digitalWrite(3,LOW); //--> D3
// digitalWrite(4,LOW); //--> D4
// digitalWrite(5,LOW); //--> D5
// digitalWrite(6,LOW); //--> D6
// digitalWrite(7,LOW); //--> D7
// digitalWrite(8,HIGH); //--> B0
// digitalWrite(9,HIGH); //--> B1
// digitalWrite(10,HIGH); //--> B2 SSO
// digitalWrite(11,HIGH); //--> B3 MOSI
// digitalWrite(12,HIGH); //--> B4 MISO
// digitalWrite(13,HIGH); //--> B5 SCK
// digitalWrite(14,LOW); //--> C0
// digitalWrite(15,LOW); //--> C1
// digitalWrite(16,LOW); //--> C2
// digitalWrite(17,LOW); //--> C3
// digitalWrite(18,LOW); //--> XX
// digitalWrite(19,LOW); //--> XX
// digitalWrite(20,LOW); //--> XX
// digitalWrite(21,LOW); //--> XX
// digitalWrite(22,LOW); //--> XX
// digitalWrite(23,LOW); //--> E0
// digitalWrite(24,LOW); //--> E1
// pinMode(A2, INPUT_PULLUP); //-->25 (ALSO C2)
I received new PCBs early December, getting around to populating and bringing them up now. Here are the notes:
1. SDO/ SDI routed incorrectly everywhere, reversed on the radio and reversed on the programming connector.
2. LEDs are BRIGHT with a 100 ohm resistor. Maybe we'll go with less bright? TBD.
R13 & 14 are 100 ohm, the rest are 124 ohm
3. AA battery holder is bigger than the footprint was designed for. The oscillator and the on/off switch interfere. Not a show stopper here, but should be fixed for the next rev.
4. For battery life, we're using a AA 1.5V battery. There's a voltage divider measuring the battery which gives an input to pin 19: ADC6/ E2.
Sophi Kravitz
I need seen everything
"Trick: open -n -a EAGLE in terminal to see more than one instance"
Sweet, Just learned this!! Thank yooou!!!
