PocketAdmin
oshw keystroke injection device ( badusb )
Public Chat
Starting from
$23.00
krakrukra has 167 orders / 7 reviews
Ships from Russia
This is a keystroke injection device (also called badusb). It is similar to a well-known USB rubber ducky made by hak5, but has much extended functionality, lower price and is also completely open source. It looks and feels like an ordinary USB flash drive, but acts as a keyboard that types in a preprogrammed payload. This payload can do anything from configuring a network to installing a reverse shell, since the device can basically do whatever an admin can with a terminal, but taking only a few seconds. This makes it a very powerful tool for automating sysadmin tasks or use in penetration testing.
For more information check its github repository:
https://github.com/krakrukra/PocketAdmin
  • 1 × BOM.txt is available in the github repository
  • Project Log
    Radik Bechmetov06/21/2019 at 16:55 0 comments
    2020, january - new 1.3 revision hardware is released, a lot of new features added
    2019, september - implemented FTL, greatly increased MSD access speed
    2019, june - big documentation improvement, first samples available for sale
    2019, may - added OS fingerprinter, keyboard layout changing
    2019, february - added many new commands, fixed bugs
    2018, december - added MSD capability
    2018, october - finished first HID only version
View project log
View all instructions
Radik Bechmetov wrote 02/01/2020 at 20:20 point
A new 1.3 revision hardware was released recently;
changelog is abailable here: https://github.com/krakrukra/PocketAdmin/issues/3
Also, some new videos are available on my youtube channel:
https://www.youtube.com/channel/UC8HZCV1vNmZvp7ci1vNmj7g
bryklinop wrote 09/08/2019 at 12:27 point
This is very nice and cool post tahsnk for this ..........!!!!!!!!!!!!!!!!!!!!!!!!
http://10-0-0-0-1.mobi/192-168-10-1.php
Radik Bechmetov wrote 07/25/2019 at 12:02 point
No. it has a very different microcontroller, and you will
not be able to reuse any/most of the code here. If you
would have a board like this with STM32F072C8T6
(or other ones with the same USB peripheral), then
you could modify the source code and get an HID-only
version. But that's a lot of work to get a bad result, so
I would not recommend that. After all, it is not all that
complicated to actiually build the normal unit if you wish.
zoobab wrote 07/25/2019 at 13:12 point
I am not talking about reusing the same code, just doing arriving at the same result.
Radik Bechmetov wrote 07/25/2019 at 13:59 point
You could make it somewhat similar, but not quite the same.
e.g. payload scripts should fit in flash, but you wouldn't be
able to store files there (because there is too little storage space);
you do not have a MSD-only button, so you would have to work around that;
it will not look like a flash drive, so you won't be able to really
use it for pentesting;
a lot of device's functionality is built upon a completely
custom USB stack that I wrote from scratch, which is why
things like OS fingerprinter are possible. So you would
have to either not have that, or reimplement all this yourself;
and also probably a lot of other things will not be the same,
which I forgot to mention here
zoobab wrote 07/25/2019 at 11:50 point
Could you use a reflashed 2EUR stlinkv2 dongle to do the same?
See here:
https://blog.danman.eu/st-link-clone-as-stm32-dev-board/
https://www.hobbiton.be/blog/repurpose-stlink/
They can behave as HID keyboard, but I don't know if there is enough space to store the payload.
There should be arduino IDE support...
Radik Bechmetov wrote 07/25/2019 at 08:54 point
Well, yeah. What is so shocking?
Radik Bechmetov wrote 07/25/2019 at 16:17 point
OK, so apparently someone flagged my snapshot files as evil
and google wants to block access to them now, so I removed
them. If you want to get the project files, just go to the github repository.
