U.S.S Enterprise 1701D
U.S.S Enterprise 1701D Model. Fully controllable sensitive touch interface for lighting system.
Behold, the U.S.S. ENTERPRISE™ NCC-1701-D clear polystyrene edition, with custom lighting and a touch pad lighting interface. For reasons I can’t explain, Enterprise D to me is the sleekest and most modern looking of the enterprises, which is why I chose it as my very first attempt at modeling. Although I enjoyed building models as a kid, this model is my first attempt at making something that looks semi-respectable. The lighting system consists of numerous led lighting strips, and few led omnidirectional towers. I suppose what makes this build unique to others is the base. The design was actually made in powerpoint, following the LCARS design principles. Certain design icons such as the warp drive and the enterprise diagram were taken from previously made schematics. The touch panel itself is actually a bit misleading in design. I’ve used an Arduino Uno with 3 capacitive touch sensors placed underneath the acrylic sheet, corresponding to the respective activating
Tom Nardi wrote 06/06/2019 at 00:11 point
Absolutely incredible. Will you be posting more info on how everything was put together?
sebastian wrote 06/06/2019 at 00:54 point
Hey Tom. Thanks! This was done a few years ago and I'd have to go searching for much of the pictures I took. To be honest, it broke down some time ago because of my shady electrical skills. (this was my first electrical/arduino project). So I actually have to rebuild some of it. I've been looking for an excuse to fix it up. When I do, I'll make sure to share!
