uTracker
a device you can use like tracker or node of CAT-M1/NB1/GSM
following the line of the last project (square inch tracker) I come again with other tracker.
Global IoT Modem
eSIM
Battery charger
GNSS
I'm very in love with tracking devices and the solutions they can reach like never lose your pet (I have a cat) maybe track people or cars and the importance of these devices becoming smaller every day.
my goal with this project is
Use a combination of components like Modems and GPS modules connected to a MCU to send an accurate location to other device.
The specs are the follows
USB port to charge, power and communicate to the MCU
Battery charger
status led indicator
Modem LTE Cat M1/Cat NB1/EGPRS
eSIM
GNSS
Dimensions
1.25inx1.25in
uTracker.pdf
Schematics for uTracker
Adobe Portable Document Format - 606.31 kB - 06/07/2019 at 16:54
Preview
Download
  • GPS problem/solution
    Raúl Luna07/17/2019 at 17:34 0 comments
    Hello guys, in the latest tests on the GNSS I detected some problems due to poor signal, the position not always be accurate, I reviewed the pcb design and the schematics and at the first look everything looked like be ok.
    after a few hours I realized that I don't have any capacitors of 100pf on my components bags and the design needs a 100pf capacitor, so... what value are the capacitor that I placed on the pcb? I don't know jeje.
    Now I'm waiting for the arriving of that capacitors to test the GNSS again.
  • latitude, longitude
    Raúl Luna07/05/2019 at 00:52 0 comments
    Hi guys, today I finished the firmware layer who sends the data to the internet, I tested with a free account "cute cat" from CloudMQTT and now the broker is receiving the data of my actual location, latitude and longitude every 30 seconds.
    sorry about the image my cell phone camera is dying a little every day.
  • battery ok
    Raúl Luna06/29/2019 at 16:08 0 comments
    Almost forgot to test the battery management, I checked for the battery charge and operation over battery, seems to be ok but I need to test a little more, Im writing the adc code to read the voltage, I realize that I cant read a real value if the usb connector is plugged, I totally forgot to add a charger on/off feature to read the value no matter the state of the usb. I don't know how important is cuz the pins of the charger tell me every time the state "charging, standby, no battery" so, if you have the device plugged in we can know if the battery is full charged and when is unplugged the reads of the adc tell us if the battery are too low.
    anyway... we are moving on and in the end I think we can have a functional device
  • Memory is working!
    Raúl Luna06/26/2019 at 22:17 0 comments
    after a few stumbles the data flash of the mcu is working, I defined only 100 bytes of space for the configuration and identification memory like apn, port, ip, serial number etc... all this memory are available for read and write from the user usb port.
    when I finish with this part I will write the code to assemble a chain of data and send every x minutes to a server (other modem connected to my pc).
    soon I will make some field test and then maybe a video.
  • The firmware
    Raúl Luna06/25/2019 at 21:28 0 comments
    right now I got working everything, last night I connect the uTracker with the GSM and CAT-M1 networks, unfortunately the NB-1 network are not available near to me so, nothing to do.
    the next step is write the application layer of the firmware, I don't really know how needs to work, I think the uTracker needs to have the feature to store data into the flash memory so I start for that.
    GNSS is working perfectly!
  • Its totally alive!
    Raúl Luna06/25/2019 at 01:07 0 comments
    after a few fixes due to my stupidity the uTracker is totally alive!.
    The first time, I could not make the usb work, the computer says I have a problem with the device, after a deep visual check I realized that I put a resistor instead of a capacitor in the ftdi, so I changed it and now works normally.
    Then... the Emulator don't recognized the target (MCU) I check again for some bad solder or something like that but i found nothing, I had to check the schematics and the pcb files and I found the problem...
    this area in the inner layers suppose to be a 3V3 area but I changed the clearance between  the holes and the copper layer and I did not realize that it was separated from the main area so the via hole is making contact with nothing.
    I fix this in the design but physically I had to solder a little wire between the pad and 3V3.
  • The first one
    Raúl Luna06/24/2019 at 20:27 0 comments
    Ok, I finally finish of assemble the first uTracker and I think I'm a little more blind after solder 0402 size components.
    there is just a couple of capacitors and resistors missing but nothing important to test the major of features while that components arrive from the store.
  • the happiness box
    Raúl Luna06/21/2019 at 21:49 0 comments
    the pcb s just arrived to me.
    oh! man look at this beauty
    I need to get all the components into a box and start to solder all of them, first I will solder the modem cuz he need a lot of heat and I don't want to de-solder other components in the process
  • Almost here
    Raúl Luna06/19/2019 at 19:35 0 comments
    The PCB's almost here.
    next weekend will be very fun cuz I want to assembly a couple of PCB's, since I have to solder a lot of components I think I need go to the market and get a jar of soldering flux.
  • Production
    Raúl Luna06/12/2019 at 21:42 0 comments
    The fabrication files are already with the manufacturer, I ordered 10 pieces. the price for 10 and 5 are the same so, if works fine I have 10 by the price of 5 if not... I hope works fine.
View all 15 project logs
Trent Torkar wrote 06/13/2019 at 09:23 point
Looks good, have you assembled yet?
Raúl Luna wrote 06/19/2019 at 19:22 point
Thanks, I still waiting for the PCBs, I think they arrive to me by the weekend.
