• Frame Driver High Level Design and Component Selection
    Alan Green4 days ago 0 comments
    The purpose of the Frame Driver is to receive a "frame" of data from the Raspberry Pi and then output it until it receives a new frame. The Frame Driver will guide the laser beam around a path over the course of 1/30th or 1/50th of a second, turning the beam on and off as appropriate, and then do it, over and over again.
    There are several steps between receiving a frame from the Pi, and outputting voltages to the Laser Galvos.
    High level block diagram showing Frame Driver components
    Frame Driver and its components
    Microcontroller
    I've decided to use a ‎‎PIC32MX170F256B-50 microcontroller. There were several reasons:
    • The PIC32 is big enough that things are easy. It's definitely possible to do this with a smaller controller - see cfavreau's Arduino-powered Open Laser Show DAC - but I didn't want this to be hard to program, and I have no intention of large-scale production. 50MHz, multiple SPI peripherals, 64k of RAM and 256k of flash is more than enough. Cheap 32 bit arithmetic will likely help, too.
    • The PIC32 is a relatively simple, controllable processor. I will be able set timers and handle interrupts to microsecond accuracy. The problem with Raspberry Pis and BeagleBones in this application is that they multiplex so much that they are no longer able to faithfully handle strict timing requirements. Listening to Bart Dring on The Amp Hour #438 talking about the ESP32 GRBL interpreter, the ESP32 could probably handle the timing requirements, but it's not trivial.
    • I've been wanting to learn PIC32 for a while now.
    DAC
    I chose MCP4822 dual 12-bit DAC. It has an internal 2.048 voltage reference and has an SPI interface.
    In this post on laserpointerforums.com, the consensus seems to be that an 8-bit DAC is not sufficient, but that a 12-bit DAC is plenty. 12 bits gives 4096 steps, which would be somewhere between 0.2 and 0.4mm per step on my kitchen wall, which seems sufficient, especially given that the laser beam is 1-2mm mm wide. Beyond 12 bits, things start to get quite pricey, and there's little additional advantage in having 0.05mm precision over 0.2mm precision at normal view distances.
    For the cheaper DACs, there are two common standards for loading data: I²C and SPI. Generally, SPI is a faster protocol, both in terms of physical link speed and in having a lower protocol overhead. The MCP4822 can transfer data with a 20MHz clock and I am expecting to be able to use at least 5MHz.
    Outputting two values from the MCP4822 DAC requires two 16 bit SPI transfers and then setting the LDAC pin low. At 5MHz, this will take (16 * 0.2 * 2 + a bit)μs ~= 8μs, which is fast enough. The DAC requires a "typical" 4.5μs to change its output signal from one level to another, anyway.
    To ensure that the internal voltage reference is stable, a very stable power supply is required.
    Voltage Shifter
    The final component in the Frame Driver is the voltage shifter which takes two single-ended 0-2.048V signals and amplifies them to the +/-10V differential signals (maximum magnitude of any given line is +/- 5V) expected by the Galvo controller boards. It will be composed of 4 op amps, in a single package. I chose the TL084, because cfavreau used it successfully in his Open Laser Show DAC. It's also the same part used on the Galvo driver boards.
    Power
    Finally here is how I plan to power each of the components:
    ComponentWhat it NeedsHow it Will Get it
    PIC323.3V, < 100mA. Pull from RPi 3.3V pins
    MPC48223.3V, a few mA, low rippleDedicated 3.3V regulator running from from RPi 5V pins
    TL084+ and - 8V supplies, <20mADedicated regulators running from Galvo +/-15V supply lines.
  • First Light
    Alan Green06/08/2019 at 11:22 0 comments
    In which I wire up the laser galvos in minimal way, validate some concepts and learn some new things.
    Turning on The Galvos
    Here's what I did. At each step I was careful to test to make sure that no smoke came out and that everything behaved as expected.
    1. Wired up the power supply to a mains plug,
    2. Connect power to the driver boards
    3. Connect the driver boards to the galvos
    At that last step, the galvos moved! I had not been expecting them to move, but it seems that their off position is at one end of their range.
    At this point, I used Blu-Tack to hold everything down, just to make sure nothing got lost in the tangle of wires. These are the grey blobs you can see in the photos above.
    I then stole the cat's spare laser pointer, Blu-Tacked it in place and lo! there was a dot.
    Signal Generator and Pretty Patterns
    I have a dual-channel signal generator. Using a Blue Board #01 I soldered up a couple of connections. Each driver board is fed by three wires: ground, V+ and V-, with V+ and V- carrying a differential signal of up to 10V. I tied each driver board's V- signal to ground, then piped in the signal to V+.
    The resulting patterns look different on camera than they do in real life, but are interesting nonetheless. The shapes are correct even if the colors are not.
    Lissajous Pattern
    The ABC of Lissajous
    Another pattern, Lissajous like
    Space uniform logo
    3rd example Lissajous pattern
    Neon crochet pillow
    Here are some things I learned:
    • The upper frequency limit is around 1kHz. Above that, the range of movement becomes limited.
    • Above 500Hz or so, the movement of the galvos makes an audible sound. The sound becomes louder with higher base frequencies, with larger signal amplitudes and with more complex waveforms, especially those with higher frequency components.
    • The driver board heat sinks get quite warm.
    • The power supply does not really get warm
    • 50Hz is plenty for making a stable looking image.
    • The mirrors and galvos have momementum and it causes overshoot and undershoot.  Any drawing sequence is going to need to take these physical effects into account because it's not like drawing pixels on a screen.
    • I will need a higher power laser for day time viewing. The cat laser is going strong after several hours.
    I think this is going to work!
  • Looking at the Galvos
    Alan Green06/08/2019 at 05:43 0 comments
    What I Bought
    I bought the cheapest laser galvo mirror set that I could buy, that also had reasonable shipping. I ended up with this one.
    Picture of a laser galvanometer set
    The kind I bought
    The set comes with the twin galvanometers, mounted on a metal block, two driver boards and a power supply. It cost about 100AUD on eBay (listing). Several of the sets on sale also offer a "show card", which will run laser displays from an SD Card. I wanted to build the display logic myself, so I didn't buy a show card.
    The specs from the listing are:
    -Input voltage:15V
    -Peak current: 1A
    -Rated current:0.5A
    -Operating temperature:0~50℃
    -Rated scanning angle:± 20 °
    -Maximum scanning angle: ± 30 °
    -Drive plate size:76mm × 48mm × 26mm
    -Wavelength:380nm-700nm
    -Analog signal input impedance: 200K ± 1% Ω (differential input)
    -Analog position input range: ± 5 V.
    -Scanning speed:20Kpps
    -Lens reflectivity:> 98% @ 45 ° incidence (coverage wavelength: 380nm-700nm)
     Important to note here:
    • They are rated for 20kpps (20,000 points per second) at 20°. Here is a description of how that test is supposed to have been done. Note that, at the rated speed, the produced pattern looks different to how it does at a lower speed. The galvo mirrors aren't magical after all - they take a finite amount of time to move into position.
    • The galvanometers are rated as consume 1A 15V, peak. That's quite a bit. One can see why a driver board is required.
    • Input impedance is high, which is good.
    Given the amount of power consumed, I think it's probably a good idea to aim for smaller angles of defletion and slower scan rates.
    Power Supply
    The supply came with two 3 pin connectors pre-attached to the output screw terminals. I confirmed with the multimeter that FG is connected to the chassis, while N & L are not. The G terminal is not connected to FG or to N (or L!).
    +/- 15v supply that came with my laser galvos
    Supply and Connectors
    Label on the power supply says it supplies 1A at 15V, which nicely matches the peak current draw spec.
    Input 100-240VAC 0.5A. Output +15V 1A, -15V 0.5A.
    There's quite a difference between input power rating (0.5A@100V = 50W) and output rating(1.0A@15V + 0.5A @ 15V = 22.5W). I suppose this means that the supply gets hot.
    This is all about what I expected.
    Galvos and Mirrors
    As noted above, the galvanometers are firmly aligned in a metal block. Under the block are screw holes which are obviously useful for securing the block.
    Galvanometers with mirrors, attached to a metal block
    The interesting bit
    Hmm... looking at the photo, that mirror seems a little dusty. I'll need to clean them. The galvanometer PCBs each have the galvanometer, the connector, and nothing else:
    I'm not entirely sure why the connectors have 6 terminals each, but based on the cables, I'm guessing the galvos give some kind of feedback to the driver board.
    Driver Boards
    These boards are responsible for amplifying a high impedance, 10V differential signal into a low impedance 15V signal.
    I've marked the connectors with their apparent function. There's signal input, two power connectors and an 8 pin output connector. The picture at the top of the page shows the cables that run between the 8 pin output connector on the driver board and the 6 pin connector on the galvo. The conductors run in two bundles.
    Trimpots and Unknowns
    The trimpots along the bottom each have two-letter markings on the underside of the board. I've put these markings in the picture. Based on this Aliexpress listing for a similar product, I'm guessing the meanings are:
    • PS = Position Scale
    • LIN = Zero Offset
    • LFD = Low Frequency Gain
    • HFD = High Frequency Gain
    • SG = Servo Gain
    • IS = Input Scale
    All of them appear to be locked with a small amount of glue, except Input Scale. I won't touch any of them.
    There is a 2x3 header area with two jumpers on it, next to the input. No idea what that is for.
    Similarly, there's a 2 pin connector in between the trim pots that I have no idea about.
    ICs
    The 3 14-SOIC packages on the driver board appear to be TL084 Quad JFet Op Amps (datasheet), which cost about 0.20USD...
  • The Plan
    Alan Green06/08/2019 at 02:20 2 comments
     A picture of my kitchen, showing where I plan for the clock to go
    Kitchen, with VR Overlay
    I want to replace our kitchen clock with one that glows in the dark. I was inspired by this instructable from DeltaFlo and encouraged by further write ups such as this one from Barton Dring and  this one from Vulcaman.
    Napkin Diagram
    Hand drawn block diagram of Laser Galvo Design
    Current Thinking
    For someone of my skill level, this will be a complicated build:
    • I'm choosing Raspberry Pi for the controller. There are several other good options: Beaglebone might obviate the need for a separate MCU, ESP32 is cheap and in vogue right now. However, Raspberry Pi is well supported and has plenty of compute power.
    • The Pi will have a physical and a web UI, accessible from the local LAN. The Pi will get its time from the internet.
    • The Frame Driver draws the same thing over and over, until it's told to draw something different. It will be powered by a small microcontroller, and its output will be two ±5v differential signal.
    • Complicated power supply. First, the Frame Driver's DAC will need a rock solid supply in order to accurately produce a signal for the mirror drivers. Second, that signal needs to be amplified from 3.3V to ±5v.
    Questions To Answer
    I will begin by addressing uncertainties:
    1.  How good are the galvos and their drivers? What kind of accuracy can I expect in drawing?
    2. Do I need really to produce a ±5v signal, or is 0-10v good enough?
    3. What laser should I use? I want one that can operate continuously (for years, I hope!) show brightly and still be eye-safe.
    4. Where did I put that Raspberry Pi and its power supply?
