Arms
A project log for Wall-E
A small-size, low-cost, Wall-E robot. Remote controlled from a HTML5 interface, through WiFi websockets.
etienneEtienne 06/10/2019 at 19:580 Comments
The shoulder is a piece of 2mm aluminium board, cut and bent to shape.
The arm is a 25mm square aluminium extrusion ; a square hole is cut, to fit a MG90S servo.
