The head is assembled from several layers of 11mm plywood, routed on my homebrew CNC.
My CNC is not very accurate, but after a bit of sanding and a few layers of paint it should look ok.
A project log for Wall-E
A small-size, low-cost, Wall-E robot. Remote controlled from a HTML5 interface, through WiFi websockets.
