This project of mine is more of a learning curve to understand the working of the E32 LoRa module from eByte which is a high power 1-watt transceiver module.
Once we understand the working, I have designed a PCB which is a breakout for this E32 module which exposes the UART bus for directly talking to the E32 module without any external circuits.
Lastly, we will test our module by setting up a link between 2 modules and send/receive data using this LoRa link.
Checkout UTSource for electronic components for your DIY Projects with free shipping: https://www.utsource.net/
Let us start with the fun now
2
Parts
You can find the LoRa modules from eByte on the following links from LCSC:
You must check out PCBGOGO for ordering PCBs online for cheap!
You get 10 good quality PCBs manufactured and shipped to your doorstep for 5$ and some shipping. You will also get a discount on shipping on your first order.
PCBGOGO has the capability of PCB assembly and stencil manufacture as well as keeping good quality standards.
Do check them out If you need to get PCBs manufactured or assembled.
