E32-433T LoRa module Tutorial | DIY breakout board
Back to overview
We will use the E32 LoRa module. E32 is a 1 Watt LoRa high power module and we will also take a look at its breakout board.
ion wrote 04/23/2020 at 14:57 point
Hi,
I want to try your project. PCB Gogo sell your boards or i have to make them. I would prefer to send your gerber files if it is OK with you. Or you can sell me the PCB if you have extra made.
Next question is functionality. You use FTDI and a PC probably to send data back and forth. What i want is to use a microcontroller on each side, and use LORA as a wireless bridge.
Please reply to me here or write me directly at igeorge@rogers.com
Thank you
