Success linux start
A project log for Redphone
The Redphone project is an open source mobile phone
vasilii-chumakovVasilii Chumakov 08/06/2019 at 23:111 Comment
Tonight I've done the linux loader util.
Step by step guide:
1. build kernel
use default config for stm32:
make ARCH=arm CROSS_COMPILE=arm-none-eabi- stm32_defconfig
setup CONFIG_DRAM_BASE, CONFIG_DRAM_SIZE, CONFIG_XIP_PHYS_ADDR
make ARCH=arm CROSS_COMPILE=arm-none-eabi- menuconfig
make:
make -j ARCH=arm CROSS_COMPILE=arm-none-eabi-
preparing & compile correct DT
2. coping xipImage & *.dtb on SD card
3. run load command
Next step - build latest busybox and make rootfs.
colton.baldridge wrote 08/12/2019 at 20:22 point
Wow, I never even thought it was possible to run Linux on an STM32F4, very impressive.
