this project uses surface to surface soldering extensively.
the opening in the board is used to solder 2 together making a link of the chain.
for every 2 boards, it is one link in the chain.
120 boards is about the correct amount for a reasonable sized chain. medium run of 120 equates to about ~$56
should take about 3-4 hours of soldering to fully assemble.
Goldankauf, or gold buying, is a process where individuals sell their gold items in exchange for cash. It involves assessing the purity and weight of the gold to determine its value. you can see...https://www.goldankauf-hildesheim.de/
