ESP32 with E32-433T LoRa module tutorial | Arduino
We will be interfacing the high powered E32 1 Watt LoRa module from eByte with an ESP32, the same method is used for an Arduino or a ESP8266
Public Chat
Checkout UTSource for electronic components for your DIY Projects with free shipping: https://www.utsource.net/
E32_2.rar
GERBER FILE
RAR Archive - 73.76 kB - 06/16/2019 at 10:42
Download
  • 1
    INTRODUCTION
    Hey, what's up, Guys! Akarsh here from CETech.
    This project of mine is interfacing the E32 LoRa module from eByte which is a high power 1-watt transceiver module with an ESP32 using Arduino IDE.
    We understood the working of the E32 in our last tutorial, this time I have designed a PCB which will connect the ESP32 to an E32.
    Lastly, we will test our board with another LoRa breakout module and set up a connection.
    Let us start with the fun now.
  • 2
    Parts
    You can find the LoRa modules from eByte on Aliexpress.
  • 3
    Get PCBs for Your Project Manufactured
    You must check out PCBGOGO for ordering PCBs online for cheap!
    You get 10 good quality PCBs manufactured and shipped to your doorstep for 5$ and some shipping. You will also get a discount on shipping on your first order.
    PCBGOGO has the capability of PCB assembly and stencil manufacture as well as keeping good quality standards.
    Do check them out If you need to get PCBs manufactured or assembled.
View all 9 instructions
