There are two versions of top case cover -- with and without hackaday logo. To print version with logo on single-extrusion printer, you need to slice the case and all Logo*.stl files separately (ensure they have the same offset on the printer's table). Then print logo, replace the plastic and print the rest of the case.
Max
BalinTech
CriptasticHacker
Dan
Wait... why is that badge green? Did you roll your own? That's hardcore!
