Code-base is espressif's a2dp_sink example: https://github.com/espressif/esp-idf/tree/master/examples/bluetooth/a2dp_sink
Unfortunately I still did not have much time to document the project properly. However if you are a bit familiar with the ESP32 and ESP-IDF, you should get along with the instructions :)
Hey, link to code seems to be broken. Great project!
