Core64 Beta Kits Shipping Now!
04/30/2021 at 02:38 • 0 commentsThis milestone was a long time coming! I'm finally releasing some of these into the wild for you early adopters to get your hands on experience... and provide me some feedback!
I won't make you log in to a BBS to buy a Core64 Beta Kit. Instead you can do that at www.Core64.io.
I look forward to feedback so I can polish the product a bit. For now, I have to switch gears to get some real manufacturing set up, and give the firmware some attention so users can get into it quickly and create their own interactive core memory experiences.
Core64 Beta Kit Assembly Update
04/10/2021 at 22:18 • 0 commentsI am closing in on completing 10 beta kits... This reinforces the idea that I do NOT want to do production myself. Even with robots.
The kits are coming together nicely, especially since I switched to a custom LED Matrix board. The fit is just perfect and I'm very happy with it. The kit has 5 different subassemblies: Logic Board, Core Board, LED Matrix, Teensy 3.2, Stylus. It's a lot of work to pull all of this together, but the results are worth it.
Another change I made was the introduction of a magnetic stylus made from a PCB. It goes together well, and completes the kit without any 3D-printed parts. Yes... the recipient of the kit gets to assemble the stylus too! There are two magnets captured in the tip. The stylus is completely passive. Here are all of the parts of the kit:
If you'd like to be the first to know when the beta kits go on sale, please sign up at www.Core64.io.
Core Memory + Neon Pixels
01/03/2021 at 13:54 • 0 commentsWhile browsing Hackaday.io I found an opportunity to collaborate with [Muth] and we put Core Memory and Neon Pixels together. They seem to be made for each other:
[Muth] built a fantastic project which stands on its own with hundreds of hand-crafted Neon Pixels. Both the individually controlled pixels and the combined 8x8 arrays are works-of-art on their own. I thought they would make a great match with interactive core memory, so I made a "Neon Pixel Edition" prototype with help from [Muth].
Neither of us plan to make the Neon Pixel version available for sale, but it was a very satisfying project to combine our projects. Look for me at the next VCF and try it out!
BUILD YOUR OWN CORE64 + NEON PIXELS DEMO
If you'd like to make your own Neon Pixels, all of the details are available at Github. To hold the Neon Pixel module you will find the mechanical CAD available at OnShape. The Neon Pixels are connected to the Core64 Logic Board through SPI Data/Clock lines accessible on the bottom row of X1, the large double row header intended for the alternate use of an Adafruit 3.2 inch TFT board.
I have a limited quantity of the unpopulated Neon Pixel Edition core boards available which are slightly larger than the standard core board - contact me if you'd like one. You will need to populate the components and headers and create the wire extensions.
See the Core Board PCBA components list at Digi-Key.
And maybe some of these components at Digi-Key.
The standard mainline demo firmware for Core64 has a #define to enable support for the Neon Pixels.
There are a few references to these INS-1 tubes on Hackaday. Sometimes they show up in Nixie tube clocks, and they go by various names like Nixie tubes, neon dot bulb, ИНС-1, neon lamps or bulbs. Seems like they were manufactured in the 80's, but I haven't found much information on them. If you know more about their history, please share that in the comments. In 2025 we met in person at Hackaday Europe, along with [Anders Nielsen} to show off the collaboration of Core64 + Neon Pixels + 65uino!
I'm still moving forward with the basic configuration of the Core64 kit which uses RGB LEDs:
Kits are available for sale at www.Core64.IO.
Latest Core Board Assembled - Design Lock is within reach
11/06/2020 at 02:18 • 0 commentsThis what I think will be the final core board configuration.
All of the functionality is tested, except I haven't physically made a core stack yet. I'm happy with the ambient light sensor and hall sensor "buttons" hiding under M - + S. The layer select function works well too, composed of solder jumpers and the two big chips in the top of this photo:
I'm also quite happy with the weaving in this one. This is my best one yet thanks to a 3D-printed assembly fixture. The fixture helps guide the sense wire crisply. My vision of making the cores easier to thread by placing the fixture on from both sides of the PCB has not yet been realized, but manually weaving plane isn't too bad... after some practice on the first two.
In the last project update I thought I could get to the point I have 8 of these stacked by now, but other priorities called. I will get these stacked after I complete the Logic Board layout. I'm reviewing the schematic now and wrestling with which features to drop from an over-crowded board. This board WILL have the ability to drive all 8 layers of core planes, and that is going to be fun when I get all the core planes visualized in real-time on an LCD!
Time for another round of prototypes
08/27/2020 at 04:00 • 0 commentsI've kicked off another round of prototypes with what I think is the final configuration. I'm sticking with the dual board design.
The top Core Board will have four I2C hall sensor buttons in the bottom edge of the frame to enable more flexibility with the user interface (Mode, Set, Minus, Plus). The hall sensors read flux strength, and that makes the sensitivity tunable versus the hall switches which use a fixed flux level for activation. I am also now including an ambient light sensor (upper left corner of this rendering) to automatically adjust the LED array brightness. The LEDs in the LED array have a dynamic range that needs to be adjusted for dim and bright conditions or they end up being blinding in low light, and unusable outside in the sunlight.
There are also some traces and pads to allow me to experiment with stacking 8 core planes on a single logic board. Look for that as an entry in the Circuit Sculpture Challenge. I've got something unique planned for that.
EDIT: I was not able to dedicate enough time to this project to enter the contest... But I'm still making progress on the goal of stacking 8 planes. See the next update for more details.
The core boards and components are ordered and should arrive this weekend.
The logic board is next for update work. I have a long list of refinements pinned down, and schematic refinement will begin in the next few days. The highlights:
- Stepping up to a Teensy 3.2 because the LC doesn't have enough IO.
- Removing the slow IO expanders, so core scanning speed will be greatly increased.
- Increased usable battery voltage range of ~2.8 to 7V (1S Lipo up to 4 primary AAA or AA Lithium cells)
- Using much lower drop-out 5V and 3V3 regulators to make better use of the batteries.
- Creating more room for expansion by exposing several I2C and SPI pins for optional fun stuff: 3.2" LCD to replace LED array, Monochrome or Color 128x64 OLED, 128x32 Teensy View OLED, Micro SD Card, 2x SAO ports, and a QWIIC port.
- The battery area will accommodate being powered with an optional 1S LiPo and charge manager for those who prefer not to use primary cells.
An expansion option that I'd like to see offered is the ability to communicate between badges with magnetic fields. The first choice would be NFMC like the Defcon 27 Badge. I've also see some 3D flux sensors (Infineon) that might work, and I've considered a PN532 Breakout Board. If you have some interest in bringing something like that to life for this project, I'd like to hear from you.
Features and Accessories Questions
07/30/2020 at 03:14 • 0 commentsI have a lot of ideas for expansion to make sure there is room for easily exercising your creativity. But I need to narrow things down and get a produceable design ready.
What do you think of these as baseline features that would be included?
- 64 bits of authentic core memory (weave it yourself)
- 64 RGB LEDs (Pimoroni Unicorn Hat)
- 4 hall switches (user configurable)
- Arduino compatible Teensy 3.2 (32-bit NXP Cortex-M4 72 MHz) with all IO accessible
- Magnetic Stylus with narrow and wide field tips
- 4x "AAA" battery pack holder
- Battery Voltage Monitor
- All of the matrix drive lines, the power rails, and the sense outputs will be easily accessible
What do you think of these plans to provide the following header rows/pads for additional expansion?
- Generic I2C OLED
- Generic SPI OLED or Sparkfun Teensy View SPI OLED
- SAO Port, quantity 2
- Adafruit MicroSD breakout board
- Sparkfun QWIIC port
- Ambient Light Sensor
- Proximity Sensor
- Sparkfun LiPo manager
- Generic or Adafruit 3.2" LCD to replace LED Array
What would you consider the must-haves?
Any ideas for nice-to-haves?
If you wouldn't mind providing that feedback through the survey form on my website, I'd appreciate it:
Power Supply Improvements
07/11/2020 at 16:03 • 0 commentsI made solid progress on power supply and efficiency for the system. Time for another round of "spot the bodge wires:"
The improvements:
- Simplified ground bus: Reverse Polarity protection moved to high side to simplify all grounding.
- Reduced voltage drop/waste: Removed diode as RPP, now using only the P-CH FET.
- Increased operating voltage range: Now 3.6 to 7.0 (was 4.5 to 6.0) with these changes:
- Added 5V regulator/bus for LED array and Teensy Vin (Teensy LC max is 5.5, Teensy 3.2 max is 6.0)
- Allows use of 4x "AAA" batteries like Energizer Ultimate Lithium, because four of them is almost 7V vs. regular alkaline which might be ~6V maximum, which exceeds what the Teensy can handle. I know this by trial and error.
- Opened the door to using a 1S LiPo, if the user chooses to hack in that option. I plan to make it easy to hack in with an Adafruit Micro-LiPo Charger.
- Improved efficiency: Powering both 5V and 3V3 regulators separately from the battery/switch, not in series.
Other notable points:
- The pin/sockets are working well for the Core & LED & Teensy components. Insertion/removal force is "just right" and it makes it easy to hack and modify. I haven't bent any pins... yet.
- Lots of optional female headers making 'scoping signals much easier than using test point loops.
- Battery pack behind the core array is out of the way AND supports LED array at the right height under the Core array. Stack-up is "just right."
Do you know how to configure both the 5V0 and 3V3 regulators to be automatically bypassed when their respective input voltages drop below 5.5 and 3.8? This would increase efficiency and expand the lower limit of the battery voltage range even further. Right now the 1S LiPo only goes to about 3.6 before the system browns out, and it should easily be able to go down to 3.3 or even 3.0 to use the full range of the LiPo.
Next up, test the hall switches on analog inputs and some optional add-ons (SD-Card, QWIIC light sensor, LCD).
Dual Red Board Prototype is Working!
07/08/2020 at 02:32 • 2 commentsOn July 4th I finally got the newest prototype working. But it runs very slowly...
I chased some rabbits, learned even more, and figured out that the enable transistor has too much of a voltage drop for the system running at 3.3V. With the enable transistor, there are a total of three transistors in series for each core matrix wire. That doesn't leave much current for flipping bits. As a quick test, I soldered a jumper wire to bypass the enable transistor and then everything started working reliably. I've now replaced the transistor with a FET and gate pull-down resistor. It's just above the section in on the left above the chip, above the text CORE ARRAY ENABLE.
With respect to the core matrix drive, there are two big functional changes in this prototype from the last one (single green board). And some big "oh..." learnings.
1) The core matrix is driven from a 3.3V regulator. And it starts to drop-out around 4.3V. And with a .9V drop diode on top of that (to limit input voltage to the Teensy MCU's weak regulator), I'm wasting a lot of power.
2) The core matrix transistors are driven by two IO Expanders that are connected to the Teensy MCU with I2C. This makes the effective refresh rate a hundred times slower than direct IO pin manipulation on the Teensy. I'll be dropping those IO Expanders from the next iteration and going with more MCU IO.
Combining both of these (wasting input power, and having transistor on-times measured in ms instead of us) results in very poor battery life. That is were most of my learning is recently, but there are a several other things I've learned that I need to refine. I also have a few more peripheral functions to test, so I might uncover a few more opportunities for improvement.
Overall, I'm very happy with the progress and results. I'm getting close to being able to offer a kit that is robust, and that I can be proud of. I need to rework my power supply approach now.
LED Array Holder Prototype
05/26/2020 at 03:03 • 0 commentsThe other circuit board and components did not show up this weekend, so I diverted to other important steps. That is, BOM refinement, assembly instructions, and mechanical design.
The first prototype design of the Core+LED Array holder is now in hand, ready for testing and design refinement.
This is the direction I'm headed for a complete assembly:
More refinement is needed, but just going through one cycle of the design/make process has already illuminated some breakthroughs in the assembly process for the LED Array holder. Even at this stage, I'm surprised how quickly everything comes together for a professional look thanks to quality 3D prints.
There is a screen protector layer over the cores (transparency film) and a diffuser layer (from a scrapped LCD panel) between the LEDs and the cores. And because printing this as one part creates a lot of support material (and removal work), I diverted to a two piece design, and now I don't need as many cut-outs, so that open gap on one end of the bezel will be completely filled in. Nice discovery to figure that out after I started printing the first one.
This project is quickly picking up steam again.
Beginning assembly of the Dual Board (red) prototypes
05/22/2020 at 12:33 • 0 commentsDespite a lack of log updates, I have been making a lot of progress toward the next round of prototypes. I have moved to a dual board design which presents the core array on its own circuit board. The decision incurred a lot of work in creating two new PCBs with proper interconnections. Regardless, I'm happy with the results so far. This time the core weaving went much faster, and the results are more consistent.
The second board is twice as tall, and will support all of the logic functions. The core board will plug into the top of the logic board, like this:
I'm looking forward to receiving the logic board in the next 3 days. In the meantime, I aim to complete the assembly of the core board and complete some basic tests.
The benefits of this revised approach are:
- A more physically robust design that does not require a supporting enclosure on the back side. It also sits flat/stable on a table surface.
- All of the components on the logic board are on the top which makes troubleshooting much easier.
- The core board can be sold separately with a much lower cost so potential buyers can make a minimal investment to see if they want to follow through with the complete project before committing to the more expensive logic board.
- It is easier to assemble the smaller core board on its own.
- The sandwiched design hides the battery pack between the boards, and provides an area to secure the stylus (with 3D printed balogna between the boards).
Here's to prompt shipping by FEDEX for the Digi-Key.com components, and to DHL for the logic boards from JLCPCB.com. It'd be great to receive them this weekend, please!
Andy Geppert
